Remove the battery and the AC power
Remove the M2x4 screw of the bottom cover
Remove the bottom cover by sliding it downwards
Remove the screw holding the optical drive
Remove the screws
Remove the 3 M2x10 screws
Remove the one M2x4 screw
Gently pull the hard disk to the left
Remove the two RAM modules
Pop them out gently
Detach the two cables from the wireless module
Remove all screws from the bottom cover
Remove 7 M2x10 screws
Remove 3 M2x4 screws
Remove 2 small screws
Open the lid of the notebook
Use a plastic opening tool to pry the bottom case
Hold the upper part with one hand, and use your other hand to disconnect the black&white cable (antenna for the wifi card)
Continue to hold the upper part with one hand, and use your other hand to disconnect the black ribbon cable
Remove the upper part with the motherboard
Remove the two screws holding the VGA IC
Lift the IC
Remove the cable by first lifting the black holder and then removing the cable
Remove the white cable simply by pulling it out from the connector
Remove the touchpad cable by first lifting the black holder
Remove the two keyboard cables by first pulling out the black holders. After that the cables are released
Remove the four screws holding the motherboard
Remove the screw holding the fan
Pry out the plastic thing holding the motherboard in place
Can you please help me locate the gpu VRM on the motherboard? My gpu is faulty and needs to be rebonded, so I wanna permanently disable it.
Sorry, I can’t help you with that
Stanky -
