Asus N56VM Motherboard Replacement
  1. Asus N56VM Motherboard Replacement, Remove battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery and the AC power
  2. Asus N56VM Motherboard Replacement, Remove bottom cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus N56VM Motherboard Replacement, Remove bottom cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the M2x4 screw of the bottom cover
    • Remove the bottom cover by sliding it downwards
  3. Asus N56VM Motherboard Replacement, Optical drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw holding the optical drive
  4. Asus N56VM Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the optical drive
  5. Asus N56VM Motherboard Replacement, Hard Disk: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus N56VM Motherboard Replacement, Hard Disk: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws
    • Remove the 3 M2x10 screws
    • Remove the one M2x4 screw
  6. Asus N56VM Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the hard disk to the left
  7. Asus N56VM Motherboard Replacement, RAM: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two RAM modules
    • Pop them out gently
    • Make sure you are electrostatically not loaded
  8. Asus N56VM Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the two cables from the wireless module
  9. Asus N56VM Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all screws from the bottom cover
    • Remove 7 M2x10 screws
    • Remove 3 M2x4 screws
    • Remove 2 small screws
  10. Asus N56VM Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the lid of the notebook
    • Use a plastic opening tool to pry the bottom case
    • Be very careful when opening so that the cables in the case are not severed.
  11. Asus N56VM Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The motherboard is still connected to the bottom case by several cables, so don't try to remove it entirely just yet.
    • Hold the upper part with one hand, and use your other hand to disconnect the black&white cable (antenna for the wifi card)
  12. Asus N56VM Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue to hold the upper part with one hand, and use your other hand to disconnect the black ribbon cable
    • Remove the upper part with the motherboard
  13. Asus N56VM Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This component is attached by a cable to the lower side of the motherboard therefore it is advised to remove it.
    • Remove the two screws holding the VGA IC
    • Lift the IC
  14. Asus N56VM Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the cable by first lifting the black holder and then removing the cable
  15. Asus N56VM Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the white cable simply by pulling it out from the connector
  16. Asus N56VM Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the touchpad cable by first lifting the black holder
  17. Asus N56VM Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two keyboard cables by first pulling out the black holders. After that the cables are released
  18. Asus N56VM Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus N56VM Motherboard Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws holding the motherboard
    • Remove the screw holding the fan
    • Pry out the plastic thing holding the motherboard in place
Stanky
crwdns2935283:007/08/17crwdne2935283:0
1,268 crwdns2915208:0crwdne2915208:0
Can you please help me locate the gpu VRM on the motherboard? My gpu is faulty and needs to be rebonded, so I wanna permanently disable it.
Coll Student - crwdns2934203:0crwdne2934203:0
Sorry, I can’t help you with that
Stanky -
crwdns2942667:0crwdne2942667:0 3,523
