Read through this guide if you are experiencing problems regarding your Asus MeMO Pad HD 8 ME180A's battery.
Use a plastic opening tool to separate the back half from the front half.
Pull the back panel away from the device.
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
Ensure that you are wearing your Anti-Static Wrist Strap.
Lift the white bar on the ZIF connector and pull the metal connector out.
Using your spudger, press down on the two spots shown in order to release the cables.
Ensure that the touchscreen cables are fully disconnected.
Using a PH#0 screwdriver, remove the twelve silver 3.2 mm screws.
Pull the battery out.
