Asus MeMO Pad 7 (ME572C) Battery Replacement
  1. Asus MeMO Pad 7 (ME572C) Battery Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus MeMO Pad 7 (ME572C) Battery Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
    • The panel will be glued on and requires pressure to open.
  2. Asus MeMO Pad 7 (ME572C) Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus MeMO Pad 7 (ME572C) Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus MeMO Pad 7 (ME572C) Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
    • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
    • Carefully run the plastic opening tool along all the edges of the tablet.
  3. Asus MeMO Pad 7 (ME572C) Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
  4. Asus MeMO Pad 7 (ME572C) Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus MeMO Pad 7 (ME572C) Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus MeMO Pad 7 (ME572C) Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the ZIF connectors to release the data cables holding the battery in. Use tweezers to do this.
    • You can also use your hand to remove ZIF connectors.
    • ZIF connectors are delicate so be careful when you are removing them.
  5. Asus MeMO Pad 7 (ME572C) Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the place where the battery connector is. Disconnect the battery connectors by carefully pulling up on them using a spudger or plastic opening tool.
  6. Asus MeMO Pad 7 (ME572C) Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus MeMO Pad 7 (ME572C) Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus MeMO Pad 7 (ME572C) Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool carefully pry the battery loose. The battery is glued to the pad; slight pressure will be needed to remove the battery.
    • The casing of the battery is soft and can easily tear. Tearing can lead to the chemicals in the battery to leak out.
Tyler Tripp
crwdns2935283:008/26/15crwdne2935283:0
395 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 14-23, Meier Fall 2015 crwdns2935289:0USF Tampa, Team 14-23, Meier Fall 2015crwdne2935289:0
USFT-MEIER-F15S14G23
But whats the secret to cleaning off the glue and resealing it?
Pico Herbie - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 36,796
