Follow this guide to learn how to correctly remove and replace the speakers in your Asus L410MA-TS02.
The speakers are combined in a single assembly, so you must replace both if one is faulty.
Remove ten 6 mm screws that secure the lower case using a Phillips #1 screwdriver.
Carefully remove the lower case.
Remove the 4 mm screws that are securing the battery using a Phillips #1 screwdriver.
Grip the white battery connecter found on its side and pull it directly out of its battery port.
Carefully lift the battery and remove it from the laptop.
Remove any electrical tape and disconnect any ribbon cables in the way.
Pull the white speaker connector directly out of its port.
