Asus K55a-si50301p Wifi Card Replacement
  1. Asus K55a-si50301p Wifi Card Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p Wifi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p Wifi Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p Wifi Card Replacement, Lower Back Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 8.5mm screws using a PH0 screwdriver.
  5. Asus K55a-si50301p Wifi Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the iFixit opening tool, gently pry the plastic cover away from its original position.
  6. Asus K55a-si50301p Wifi Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull up and then towards you until the plastic cover is free.
  7. Asus K55a-si50301p Wifi Card Replacement, Wifi Card: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the white and black wires from the card.
    • This does not require much force. Simply squeeze on the sides of the connector and allow the end to pop off.
  8. Asus K55a-si50301p Wifi Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 9mm Phillips #1 screws from the wifi card.
  9. Asus K55a-si50301p Wifi Card Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After unscrewing lift gently to remove.
Zack Cannon
crwdns2935283:002/07/19crwdne2935283:0
359 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team S1-G4, Virtue Spring 2019 crwdns2935289:0Western Carolina University, Team S1-G4, Virtue Spring 2019crwdne2935289:0
WCU-VIRTUE-S19S1G4
crwdns2942667:0crwdne2942667:0 1,044
