Asus K55VD Fan Replacement
    • Power off the device completely
    • Flip the device over to its back cover.
    • Use the switches to release the battery from its adapter.
  1. Asus K55VD Fan Replacement, Hard Drive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus K55VD Fan Replacement, Hard Drive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
    • After removing the screws, remove the smaller cover.
  2. Asus K55VD Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the 1.5 mm screws that hold down the hard drive.
    The bottom left screw does not hold down the drive bay. Unsrew that screw in step 5.
    Daniel - crwdns2934203:0crwdne2934203:0
  3. Asus K55VD Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus K55VD Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the hard drive from the slot.
    • Remove the hard drive from its shell.
  4. Asus K55VD Fan Replacement, Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K55VD Fan Replacement, Fan: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K55VD Fan Replacement, Fan: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all 12 screws from the bottom cover with a Phillips #0 screwdriver.
    • The four screws nearest the display hinges are longer.
    • The single screw in the middle of the bottom cover is shorter than the rest.
    You should also unscrew the bottom silver screw and unplug the wifi antennas.
    https://i.imgur.com/vRrlRkv.png
    You need to remove the plastic cover covering the middle screw marked in orange.
  5. Asus K55VD Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K55VD Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K55VD Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After the screws are removed, Orientate the device so that the keyboard is shown.
    • Using the Plastic Pry tool separate the keyboard panel from the rest of the laptop.
  6. Asus K55VD Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus K55VD Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before the keyboard panel can be fully removed, detach the three cords that connect to the keyboard.
    • Lift up on the black tab and the cord will fall out.
  7. Asus K55VD Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K55VD Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K55VD Fan Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the optical dive by sliding it outward.
  8. Asus K55VD Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K55VD Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K55VD Fan Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now remove the two wires shown by pulling away from the motherboard.
  9. Asus K55VD Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K55VD Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K55VD Fan Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three screws holding the motherboard and fan in place using the Phillips #0 bit.
    • The top left screw shown in the first picture is easily broken
  10. Asus K55VD Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus K55VD Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus K55VD Fan Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • lift up on the entire motherboard and unplug the bottom wires connected to the fan.
  11. Asus K55VD Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus K55VD Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After all cords have been removed, the fan can be removed as well.
Charter Mitchell
crwdns2935283:009/21/18crwdne2935283:0
335 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S1-G4, Riccardelli Fall 2018 crwdns2935289:0University of North Texas, Team S1-G4, Riccardelli Fall 2018crwdne2935289:0
UNT-RICCARDELLI-F18S1G4
At step 5, you should also unscrew the bottom silver screw and unplug the wifi antennas.
At step 3, the bottom left screw does not hold down the drive bay. Unsrew that screw in step 5.
crwdns2942667:0crwdne2942667:0 3,019
