If you wish to replace or upgrade the RAM inside your ASUS K55N, this is the guide for you.
Flip the laptop over, such that the bottom of the laptop is facing upwards.
Pull the latch to the right of the battery to the right.
Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
While holding the second latch from the previous step, use another hand to reach underneath the battery.
Pull the battery upwards and away from the laptop to remove it.
Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
Remove the panel by pushing away from the laptop until the panel is free of the laptop.
Lift to remove the panel.
Lift up the plastic static shield atop the RAM slots.
Depress the tongs on either side of the RAM stick to loosen the RAM from the slot.
Grab the RAM and pull away from the slot to release it.
