This guide will provide a quick and easy procedure for replacing your Wi-Fi card. This particular guide could also be referred as a prerequisite for other guides on RAM, motherboard and fan.
Close the device and lay it upside down.
Move the battery eject button to the right. The battery will be ejected.
Grab the battery and remove it from the device.
Using a Phillips #000 screwdriver, remove the two 16mm screws securing the access panel to the laptop.
Gently remove the cover once the screws are removed.
Locate the Wi-Fi card and detach both coaxial cables that are connected to the card.
Grasp the Wi-Fi card gently and remove it carefully.
