Asus GL551JW-AH71 Upper Assembly Replacement
  1. Asus GL551JW-AH71 Upper Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Upper Assembly Replacement, Optical Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Upper Assembly Replacement, Optical Drive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
  5. Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
  6. Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently grasp the optical drive assembly and slide it out of the laptop body.
  7. Asus GL551JW-AH71 Upper Assembly Replacement, Upper Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Upper Assembly Replacement, Upper Assembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
  8. Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the access panel.
  9. Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #000 screwdriver, remove the seven 11mm screws holding lower case to the laptop.
  10. Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop over and open the screen.
  11. Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pry open the case with an iFixit opening tool.
    • The upper and lower assembly are connected with a display cable that will be removed in the next step. Do not pull the parts apart more than a few inches.
  12. Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus GL551JW-AH71 Upper Assembly Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop on the right side while still holding the upper and lower assemblies close together.
    • Unplug the display connector from the motherboard.
    • Remove the upper assembly.
William Kelley
crwdns2935283:003/20/19crwdne2935283:0
1,035 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 crwdns2935289:0UMass Dartmouth, Team S8-G3, Bailey Spring 2019crwdne2935289:0
UMASSD-BAILEY-S19S8G3
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 571
