This guide outlines how to replace the RAM in the Asus GL551JW-AH71.
Close the device and lay it upside down.
Move the battery eject button to the right. The battery will be ejected.
Grab the battery and remove it from the device.
Using a Phillips #00 screwdriver, remove the two 11mm screws that hold the access panel in place.
Remove the access panel by lifting it up.
Locate the tabs holding the RAM chip in place.
Push the tabs in an outward direction from the RAM and the RAM will be released.
Gently remove the RAM from the motherboard.
