Asus GL551JW-AH71 Display Assembly Replacement
    1. Asus GL551JW-AH71 Display Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Close the device and lay it upside down.
      • Unplug the device and make sure the device is powered off before removing the battery.
    2. Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Move the battery eject button to the right. The battery will be ejected.
    3. Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grab the battery and remove it from the device.
    1. Asus GL551JW-AH71 Display Assembly Replacement, Optical Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement, Optical Drive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
    2. Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
    3. Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently grasp the optical drive assembly and slide it out of the laptop body.
    1. Asus GL551JW-AH71 Display Assembly Replacement, Upper Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement, Upper Assembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
    2. Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully remove the access panel.
    3. Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a Phillips #000 screwdriver, remove the seven 11mm screws holding lower case to the laptop.
    4. Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the laptop over and open the screen.
    5. Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently pry open the case with an iFixit opening tool.
      • The upper and lower assembly are connected with a display cable that will be removed in the next step. Do not pull the parts apart more than a few inches.
    6. Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the laptop on the right side while still holding the upper and lower assemblies close together.
      • Unplug the display connector from the motherboard.
      • Remove the upper assembly.
    1. Asus GL551JW-AH71 Display Assembly Replacement, Display Assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement, Display Assembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the three 5mm screws located in each circle with a Phillips #000 screwdriver.
      • A total of twelve 5mm screw should be removed in order to free the display assembly from the base.
    2. Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the display assembly up, separating it from the base of the device.
    3. Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using a plastic opening tool, separate the bezel from the screen.
      • Insert the tool and slide it right to left to release the bezel from the screen.
    4. Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four screws using a Phillips #0 screwdriver.
    5. Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus GL551JW-AH71 Display Assembly Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grab the screen in the corners and lift up to remove it.
Alec Pimentel
crwdns2935283:003/21/19crwdne2935283:0
258 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 crwdns2935289:0UMass Dartmouth, Team S8-G3, Bailey Spring 2019crwdne2935289:0
UMASSD-BAILEY-S19S8G3
crwdns2942667:0crwdne2942667:0 1,156
