Faulty or failing RAM can cause a variety of issues, from random crashing to a total loss of power. This guide will walk you through locating and replacing your laptop's RAM.
Power off and unplug your laptop, then turn it over.
Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
Remove the battery from its compartment.
Lift up the rubber stopper on the backplate to expose one Phillips screw. Unscrew it until it becomes loose.
Use an opening tool to pry up the backplate along its edges, then remove it.
Remove each RAM module one at a time by sliding them downward out of their slots.
What about how to remove the other two internal RAM Modules?
