Asus G73JW-XT1 Optical Drive Replacement
  1. Asus G73JW-XT1  Optical Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device over so the battery port is easy to access.
  2. Asus G73JW-XT1  Optical Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus G73JW-XT1  Optical Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the left slider to the left so that it locks in place.
    • Slide the right slider to the right while pushing the battery away from you. The battery should disconnect.
  3. Asus G73JW-XT1  Optical Drive Replacement, Optical Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus G73JW-XT1  Optical Drive Replacement, Optical Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the device off and remove any power cords. Dissassembling the device while it is under power may result in electric shock and potential damage to the device.
    • Rotate the device so the battery port is facing away.
    • Remove two 5.5 mm Phillips #0 screws on the back panel.
  4. Asus G73JW-XT1  Optical Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus G73JW-XT1  Optical Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus G73JW-XT1  Optical Drive Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the opener tool into the small groove at the edge of the panel.
    • Using opener tool, gently pry the back panel upward until it lifts free from the device.
    • Gently lift the panel off with your fingers.
  5. Asus G73JW-XT1  Optical Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 5.5 mm Phillips #0 screw directly to the right of the RAM cards.
  6. Asus G73JW-XT1  Optical Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus G73JW-XT1  Optical Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the plastic opening tool in the gap between the motherboard and the back panel, directly to the right of the RAM cards.
    • Gently push the optical drive outwards. This should require very little pressure.
    • Grab the loose optical drive with your fingers and pull it free.
Emma Plass
crwdns2935283:009/27/18crwdne2935283:0
406 crwdns2915208:0crwdne2915208:0
Oregon Institute of Technology, Team S1-G3, Lancaster Fall 2018 crwdns2935289:0Oregon Institute of Technology, Team S1-G3, Lancaster Fall 2018crwdne2935289:0
OIT-LANCASTER-F18S1G3
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 363
