Asus G501JW-BHI7N12 Trackpad Replacement
  1. Asus G501JW-BHI7N12 Trackpad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus G501JW-BHI7N12 Trackpad Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Anti-Static Wrist Strap
    $7.95
    • Attach the clip of your anti-static wrist strap to the case of the laptop. This prevents any accidents that could fry the motherboard.
    • Remove the four 7.0mm Philips #0 screws around the battery.
  2. Asus G501JW-BHI7N12 Trackpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the connector highlighted in this picture by pulling it up and out of it's seating, then pull the battery away from the motherboard and remove the battery.
  3. Asus G501JW-BHI7N12 Trackpad Replacement, Cooling Fan: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $7.95
  4. Asus G501JW-BHI7N12 Trackpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew and remove the four 5mm Phillips #0 screws from the cooling fan.
  5. Asus G501JW-BHI7N12 Trackpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 4 pin connector from mother board.
  6. Asus G501JW-BHI7N12 Trackpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide cooling fan out from underneath the copper heat sink.
    • The cooling fan will be clipped to the case, we suggest pulling it toward the front of the case. Using the spudger can be helpful to work the fan loose.
  7. Asus G501JW-BHI7N12 Trackpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • One of the fans will have a connector that partially covers it. Pull the connector loose by flipping up the plastic clamps on both ends and follow steps 2-4.
  8. Asus G501JW-BHI7N12 Trackpad Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the six 5 mm screws located along the copper heat sink.
  9. Asus G501JW-BHI7N12 Trackpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the same Phillips #0 screwdriver, remove the nine 4 mm screws located around the motherboard.
  10. Asus G501JW-BHI7N12 Trackpad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the motherboard.
  11. Asus G501JW-BHI7N12 Trackpad Replacement, Trackpad: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the three 4 mm screws attached to the trackpad.
  12. Asus G501JW-BHI7N12 Trackpad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the trackpad from its slot.
Timothy Goike
crwdns2935283:002/18/21crwdne2935283:0
277 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S2-G20, Eggleston Spring 2021 crwdns2935289:0The Citadel Military College of South Carolina, Team S2-G20, Eggleston Spring 2021crwdne2935289:0
CMCSC-EGGLESTON-S21S2G20
crwdns2942667:0crwdne2942667:0 260
