Asus F6A-X2 RAM Replacement
  1. Asus F6A-X2 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove any power cords and turn the laptop off. Attempting to replace part of the laptop while power is running through it may cause electrocution or damage to the device.
    • Flip laptop face down and rotate so the battery is facing toward you.
    • The battery is not shown in this picture.
    • To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
    • Slide the battery toward you and lift it out of the laptop.
  2. Asus F6A-X2 RAM Replacement, Back Access Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus F6A-X2 RAM Replacement, Back Access Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the laptop facing down, rotate it so the battery pack is facing away from you.
    • Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
  3. Asus F6A-X2 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus F6A-X2 RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus F6A-X2 RAM Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a finger into one of the slots on the bottom panel.
    • Gently lift the upwards, and the back panel of the laptop will come off easily.
  4. Asus F6A-X2 RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus F6A-X2 RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure to check the RAM specifications on the device page.
    • There are two white plastic tabs holding the RAM in place. Place two fingers on each of these tabs, and pull outward.
    • You will hear a pop and visibly see the RAM move upwards.
    • Slide the RAM towards the back end of the laptop (the end with the battery), and lift up to remove it.
  5. Asus F6A-X2 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus F6A-X2 RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the process from the previous step to remove the bottom RAM.
Jonathan
crwdns2935283:004/24/14crwdne2935283:0
1 174 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
Cal Poly, Team 10-56, Amido Spring 2014 crwdns2935289:0Cal Poly, Team 10-56, Amido Spring 2014crwdne2935289:0
CPSU-AMIDO-S14S10G56
Tutorel simple et très clair.
Merci
alainbadinier - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 907
