Asus EeeBook X205TA Speakers Replacement
  1. Asus EeeBook X205TA Speakers Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus EeeBook X205TA Speakers Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus EeeBook X205TA Speakers Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Speakers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the battery out of the laptop.
    Very well explained with clear pictures. Thanks!
    Şerife Balci - crwdns2934203:0crwdne2934203:0
  6. Asus EeeBook X205TA Speakers Replacement, Speakers: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and lift the tabs from the LED/motherboard ribbon cable.
    • Remove the cable.
  7. Asus EeeBook X205TA Speakers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the speaker cable from the motherboard.
  8. Asus EeeBook X205TA Speakers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the right speaker gently with the plastic opening tool.
  9. Asus EeeBook X205TA Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the left speaker gently with the plastic opening tool.
William Riggins
crwdns2935283:003/21/17crwdne2935283:0
319 crwdns2915208:0crwdne2915208:0
IUPUI, Team S3-G4, Baechle Spring 2017 crwdns2935289:0IUPUI, Team S3-G4, Baechle Spring 2017crwdne2935289:0
IUPUI-BAECHLE-S17S3G4
Thank you very much for this detailed and helpful tutorial.
andrew - crwdns2934203:0crwdne2934203:0
Thanks. You’ve helped make it clearer for me!
geometry dash
Martin Tolley - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 954
