This guide will help you replace your Asus EeeBook X205TA in case your battery is dead, dying, or won't hold a charge. If disposing battery, please follow the laws and regulations for proper disposal.
Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
Carefully pry open the case from several points.
Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
Carefully lift the battery out of the laptop.
Follow the guide in reverse order to reassemble the device.
crwdns2935229:09crwdne2935229:0
crwdns2947412:011crwdne2947412:0
By any chance , Can we run this laptop without battery ? I mean directly from AC ? Please suggest
No, you must have the battery on.
is this under warenty
If you have one….
My battery is stuck on orange led mode. My laptop cannot identify the battery….
my laptop is running on AC but the minute power is switched off it shuts. do i need a battery replacement?
Mine was doing the exact same thing. I replaced the battery and it is working fine. There are known battery issues with this model.
Merci beaucoup tutoriel bien expliqué
I found my old ASUS X205TA and the battery was dead, it would still work with AC power though. I ordered a replacement battery and used this simple guide. All went well. Thanks.
This should be a #0 Phillips driver, not a #2 Phillips driver!
Can anyone share links from where to order battery. I'm located in India. Thanks
