Asus EeeBook X205TA Battery Replacement
  1. Asus EeeBook X205TA Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus EeeBook X205TA Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus EeeBook X205TA Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the battery out of the laptop.
    Very well explained with clear pictures. Thanks!
    Şerife Balci - crwdns2934203:0crwdne2934203:0
Follow the guide in reverse order to reassemble the device.
crwdns2935229:08crwdne2935229:0
Lorena Santiago
crwdns2935283:010/06/16crwdne2935283:0
712 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-2, Sullivan Fall 2016 crwdns2935289:0USF Tampa, Team 2-2, Sullivan Fall 2016crwdne2935289:0
USFT-SULLIVAN-F16S2G2
crwdns2947412:011crwdne2947412:0
By any chance , Can we run this laptop without battery ? I mean directly from AC ? Please suggest
Sourabh Verma - crwdns2934203:0crwdne2934203:0
No, you must have the battery on.
Tayler Grant -
If you have one….
Tayler Grant -
My battery is stuck on orange led mode. My laptop cannot identify the battery….
Tayler Grant - crwdns2934203:0crwdne2934203:0
my laptop is running on AC but the minute power is switched off it shuts. do i need a battery replacement?
kiranmayi kola - crwdns2934203:0crwdne2934203:0
Mine was doing the exact same thing. I replaced the battery and it is working fine. There are known battery issues with this model.
Goran Jandjel -
Merci beaucoup tutoriel bien expliqué
tandem.2010 - crwdns2934203:0crwdne2934203:0
I found my old ASUS X205TA and the battery was dead, it would still work with AC power though. I ordered a replacement battery and used this simple guide. All went well. Thanks.
Goran Jandjel - crwdns2934203:0crwdne2934203:0
This should be a #0 Phillips driver, not a #2 Phillips driver!
Nathan Hui - crwdns2934203:0crwdne2934203:0
Can anyone share links from where to order battery. I'm located in India. Thanks
saquib - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 14,581
