Slide the battery's locking tabs from the locked position to unlocked positions.
Slide the battery out while holding the left locking tab in the unlocked position.
Identify the three metal tabs holding down the laptop's keyboard.
Using a spudger, depress each metal tab to remove the keyboard.
Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
Slide the keyboard's ribbon cable from the connector.
Remove the keyboard by lifting upwards.
crwdns2935229:014crwdne2935229:0
