Asus Eee PC 1201N Cooling fan replacement
  1. Asus Eee PC 1201N Cooling fan replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N Cooling fan replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N Cooling fan replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
  4. Asus Eee PC 1201N Cooling fan replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Eee PC 1201N Cooling fan replacement, Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the netbook to find the four small grooves along the top of the keyboard.
    • Pry the keyboard up using the plastic opening tool.
  5. Asus Eee PC 1201N Cooling fan replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Eee PC 1201N Cooling fan replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
    • Remove the keyboard.
  6. Asus Eee PC 1201N Cooling fan replacement, Cooling fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 6.5mm screws using the J0 Phillips head screwdriver from back of the netbook.
  7. Asus Eee PC 1201N Cooling fan replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Eee PC 1201N Cooling fan replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ten 4.5 mm screws from cover plate using the J0 Phillips head screwdriver.
    • Remove the cover plate by sliding the plastic opening tool around the entire edge of the plate.
  8. Asus Eee PC 1201N Cooling fan replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the blue tab for the touchpad connector before removing the cover plate completely.
  9. Asus Eee PC 1201N Cooling fan replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4.6 mm screws from the cover plate using the J0 Phillips head screwdriver.
  10. Asus Eee PC 1201N Cooling fan replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the connector.
  11. Asus Eee PC 1201N Cooling fan replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up and remove the fan.
Krishna Janjanam
crwdns2935283:011/08/16crwdne2935283:0
206 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-3, Nance Fall 2016 crwdns2935289:0USF Tampa, Team 2-3, Nance Fall 2016crwdne2935289:0
USFT-NANCE-F16S2G3
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,065
