Asus Eee PC 1008ha Screen Replacement
  1. Asus Eee PC 1008ha Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Asus Eee PC 1008ha Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Eee PC 1008ha Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Eee PC 1008ha Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Asus Eee PC 1008ha Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Eee PC 1008ha Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  4. Asus Eee PC 1008ha Screen Replacement, LCD Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Eee PC 1008ha Screen Replacement, LCD Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #00 screwdriver, unscrew the 4mm screws from the rightmost circuit board.
    • Carefully pull the circuit board away from side of device base.
  5. Asus Eee PC 1008ha Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Eee PC 1008ha Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Eee PC 1008ha Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #00 screwdriver, unscrew the 4mm screws attaching screen to base from both sides.
    • Gently lift the screen portion from the base.
  6. Asus Eee PC 1008ha Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Eee PC 1008ha Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Plastic Opening Tool, pry the six small chits from the face of the screen portion.
    • Using the Phillips #00 screwdriver, unscrew the two 2mm and four 4mm screws from underneath the chits.
  7. Asus Eee PC 1008ha Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Eee PC 1008ha Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the Plastic Opening Tool under the edge of the screen bezel to release the front panel of the screen.
  8. Asus Eee PC 1008ha Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Eee PC 1008ha Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #00 screwdriver, unscrew the 2mm screws from the perimeter of the screen.
    • Use your fingers to hold the screen and carefully lift it from the base.
  9. Asus Eee PC 1008ha Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Eee PC 1008ha Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to peel back the adhesive tape located on the back of the screen.
    • Disconnect the wire from the screen.
Michael Dooley
crwdns2935283:004/18/13crwdne2935283:0
138 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 21-52, Johann Spring 2013 crwdns2935289:0Cal Poly, Team 21-52, Johann Spring 2013crwdne2935289:0
CPSU-JOHANN-S13S21G52
crwdns2935297:011crwdne2935297:0
crwdns2942667:0crwdne2942667:0 3,204
