Asus Eee PC 1005HA Keyboard Replacement
  1. Asus Eee PC 1005HA Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the laptop upside down.
    • Locate the two battery lock tabs.
  2. Asus Eee PC 1005HA Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Eee PC 1005HA Keyboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Eee PC 1005HA Keyboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the tabs outward to unlock the battery.
    • The left tab will remain unlocked, while the right tab must be held.
    • Holding the right tab open, slide the battery out of the laptop.
  3. Asus Eee PC 1005HA Keyboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Eee PC 1005HA Keyboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
    • Do not apply too much pressure. The latches can not be removed and will bend if forced.
  4. Asus Eee PC 1005HA Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Eee PC 1005HA Keyboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Eee PC 1005HA Keyboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop over, and open the display.
    • Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
    • Gently lift the keyboard and slide it toward the screen.
    • Do not remove the keyboard completely. This can damage the ribbon cable connecting the underside of the keyboard to the laptop.
  5. Asus Eee PC 1005HA Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
    • Depending on the model, the tabs on this ZIF connector will either flip up toward the display or push out toward the display.
    • Once the ZIF connector tabs have been released, remove the keyboard.
crwdns2935229:012crwdne2935229:0
Chris Beichler
crwdns2935283:001/20/12crwdne2935283:0
585 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-22, Maness Winter 2012 crwdns2935289:0Cal Poly, Team 11-22, Maness Winter 2012crwdne2935289:0
CPSU-MANESS-W12S11G22
after i upgrade my bios keyboard stop working . but external keyboard working fine.. plz help
anytimerabin - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 23,588
