Asus Chromebook Flip C100P Battery Replacement
  1. Asus Chromebook Flip C100P Battery Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
    • Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
    For me, in this step, all the screws were T5.
    Jorge Gomes - crwdns2934203:0crwdne2934203:0
    same for me. there are no J1000 screws in this device involved in this repair.
    Fabian Aldo Santiago - crwdns2934203:0crwdne2934203:0
    also, despite the size discrepency of this instruction’s step, the top middle screw is still a different size so keep track of them.
  2. Asus Chromebook Flip C100P Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to remove the four bottom rubber feet.
  3. Asus Chromebook Flip C100P Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four screws under the feet using a screwdriver with a J100 tip.
    there are 5 screws under 3 of the foot pads (two of them have 2 screws each and one has none). the screws also vary in size so keep track of them.
  4. Asus Chromebook Flip C100P Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to pry up the palm rest assembly.
  5. Asus Chromebook Flip C100P Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two cables from the motherboard with tweezers
    very hard to put the cables back in. Be careful.
    Felipe Lyon - crwdns2934203:0crwdne2934203:0
    How do you get them back in please?
    Steve Drake - crwdns2934203:0crwdne2934203:0
    I agree. This part is tricky. (On my c100p) the connector for the smaller cable rotates on one side to unlock/lock. The larger cable has a slide to help get the cable situated. Be sure to check ALL the keys prior to putting the keyboard back on. I didn’t and the 2,w,s,and x keys didn’t work causing me to have to redo the work.
    Bryan Krusniak - crwdns2934203:0crwdne2934203:0
    Some creative placement helps: lay keyboard flat (ribbons up), fold chromebook hinge to 90 and lay on its side slightly overlapping the keyboard: this should gives the ribbons enough slack while giving us visibility and room for hands. Don’t forget to close the little “locks” on each side of the wide ribbon.
    Tweezers are a must, also don’t grab the cable like the picture shows, use the blue tag part of the cable just below to insert and remove from the connector.
    Gregg Tilles - crwdns2934203:0crwdne2934203:0
    on my unit the large ribbon had some adhesive sticking it down to the top of the speaker box and its conector had the same aforementioned slide mechanism to release it. the small ribbon on mine doesn’t appear to have any type of release mechanism that moves. the small blue tab is stiff plastic you use tweezers to pull / push with and the cable is friction fit into the socket.
  6. Asus Chromebook Flip C100P Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four J1 Screws of the Audio Cards
  7. Asus Chromebook Flip C100P Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three Battery Screws by using a screwdriver with a J00 tip.
    What is a J00 tip? Small phillips/strait tip? Allen wrench? Specific Asus tool?
    chasmark - crwdns2934203:0crwdne2934203:0
    J00 or JIS #00 is a screwdriver bit type. In this case, a Phillips #00 (PH00) should do the trick!
    Austin Blakely -
    the upper left screw by the asus logo is smaller/shorter than the other 2. keep track of them.
  8. Asus Chromebook Flip C100P Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery cable out of Mother Board
    In what direction do you unplug the cable?
    gideon morrow - crwdns2934203:0crwdne2934203:0
To reassemble your device and complete the battery replacement, please follow these instructions in reverse order.
crwdns2935229:012crwdne2935229:0
Ruofan Wang
crwdns2935283:006/27/16crwdne2935283:0
191 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-1, Rowley SU 2016 crwdns2935289:0Eastern Washington University, Team 1-1, Rowley SU 2016crwdne2935289:0
EWU-ROWLEY-SU16S1G1
The difficulty rating should be higher. The sound card does not need to be removed, but this is not mentioned. I only noticed it from the next picture. Reattaching the keyboard cable is very difficult; a hint with tips would help.
Chas Hofmeister - crwdns2934203:0crwdne2934203:0
I had to searched high and low for this but I'm glad I found this site. Thanks for a great how-to, well done. I wish other sites were a clear and concise.
Eugene Carroll - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 11,675
