Asus Chromebook C300SA-DS02 Display Assembly Replacement
  1. Asus Chromebook C300SA-DS02 Display Assembly Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook C300SA-DS02 Display Assembly Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook C300SA-DS02 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook C300SA-DS02 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook C300SA-DS02 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook C300SA-DS02 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 Display Assembly Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook C300SA-DS02 Display Assembly Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook C300SA-DS02 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 Display Assembly Replacement, Display Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook C300SA-DS02 Display Assembly Replacement, Display Assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Asus Chromebook C300SA-DS02 Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel back the tape covering the display cable.
    • Ease the cable towards the screen and out from the connector.
  10. Asus Chromebook C300SA-DS02 Display Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 driver to remove the six 5mm screws on the top right and left display hinges.
  11. Asus Chromebook C300SA-DS02 Display Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the display assembly up and away from the laptop.
Celina Monteiro
crwdns2935283:010/17/17crwdne2935283:0
233 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G7, Simcock Fall 2017 crwdns2935289:0UMass Dartmouth, Team S1-G7, Simcock Fall 2017crwdne2935289:0
UMASSD-SIMCOCK-F17S1G7
crwdns2942667:0crwdne2942667:0 225
