This guide will walk you through the step by step process of removing the display assembly from the laptop. To replace just the LED screen component within rather than the entire assembly, refer to Asus Chromebook C300SA-DS02 Screen Replacement.
Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
Remove the three 6.0mm Phillips #0 screws.
Open the laptop.
Using an iFixit opening tool, pry along the edges of the keyboard.
Lift the keyboard and slide it gently towards you.
Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
Remove the six 5.6mm Phillips #0 screws around the battery.
Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
Unplug the black and white cable from the motherboard.
Peel back the tape covering the display cable.
Ease the cable towards the screen and out from the connector.
Use a Phillips #0 driver to remove the six 5mm screws on the top right and left display hinges.
Gently lift the display assembly up and away from the laptop.
