Asus Chromebook C300MA-DB01 Battery Replacement
  1. Asus Chromebook C300MA-DB01 Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place device bottom-side up.
  2. Asus Chromebook C300MA-DB01 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 6.0 mm Philips screws from the center of the case with the #2 screwdriver bit.
    • Remove the eight 9.0 mm Philips screws along the perimeter of the case with the #2 screwdriver bit.
  3. Asus Chromebook C300MA-DB01 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, separate the bottom case at the seam.
    • Prying open a laptop requires a lot of force but use caution so as to avoid breaking the fragile connectors.
  4. Asus Chromebook C300MA-DB01 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook C300MA-DB01 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the keyboard panel away from the components at its hinges, which are located at the back of the laptop.
  5. Asus Chromebook C300MA-DB01 Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 6.0mm Philips screws, using the 64 bit driver from around the battery.
  6. Asus Chromebook C300MA-DB01 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the wire using the plastic opening tool that connects the battery with the board.
  7. Asus Chromebook C300MA-DB01 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out of the laptop
wyatt boyatt
crwdns2935283:009/25/17crwdne2935283:0
541 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S4-G3, Eyestone Fall 2017 crwdns2935289:0USF Tampa, Team S4-G3, Eyestone Fall 2017crwdne2935289:0
USFT-EYESTONE-F17S4G3
crwdns2942667:0crwdne2942667:0 2,363
