Asus Chromebook C300M Battery Replacement
  1. Asus Chromebook C300M Battery Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the Chromebook over, bottom-side up.
  2. Asus Chromebook C300M Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook C300M Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws from the 11 spots using the aluminum driver with the J00 Philips head provided in iFixit toolkit.
    • Remove the eight 9.0mm Philips screws along the perimeter of the case.
    • Remove the three 6.0mm Philips screws from the center of the case.
    • Some versions may instead have six bigger screws (the four on the upper side of the image, close to the hinge, and two on the sides) and five smaller ones (four at the bottom of the image, where the laptop is thinner, and one in the center).
  3. Asus Chromebook C300M Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, work around the Chromebook separating the plastic case at the seam.
  4. Asus Chromebook C300M Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the Chromebook at hinges.
    Shouldn’t you disconnect the battery?
    Sam LH - crwdns2934203:0crwdne2934203:0
  5. Asus Chromebook C300M Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 6.0mm Philips screws from around the battery. Make sure to disconnect the battery from the motherboard.
    Make sure to disconnect battery wire from the motherboard
    Landon Halley - crwdns2934203:0crwdne2934203:0
  6. Asus Chromebook C300M Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out of the laptop.
crwdns2935229:016crwdne2935229:0
Jake Van Loon
crwdns2935283:009/25/15crwdne2935283:0
1,010 crwdns2915208:0crwdne2915208:0
University of Tampa, Team 1-1, Whiteside Fall 2015 crwdns2935289:0University of Tampa, Team 1-1, Whiteside Fall 2015crwdne2935289:0
UT-WHITESIDE-F15S1G1
crwdns2947412:011crwdne2947412:0
It's not clear from these instructions how to actually disconnect the battery's wires from the main board... can you provide some guidance there?
Mike Kelly - crwdns2934203:0crwdne2934203:0
PLS ANSWER MIKES QUESTION. You cant just remove the battery without disconnecting a wire which seems fragile so I can not go any further without this instruction. sighhhhhhdsgkhdsf;gklfxgbl;dfkbn; so annoying.
Aaron Simich - crwdns2934203:0crwdne2934203:0
I replaced the battery, no problem Thank you Jake Van Loon and 4 others. My current problem is - in the process of replacing the battery the thin white strip that comes down from the top became disconnected. I notice in Step 4 of the Battery instructions that the strip is attached but in Step 5 is isnt. Can someone explain to me just how to reconnect that. Please. Any help is truely appreciated.
cc manley - crwdns2934203:0crwdne2934203:0
The battery plug is like no other I have ever seen.
Can / Will anyone comment on how to unplug it?
Thanks in advance
kaulad - crwdns2934203:0crwdne2934203:0
Fail. Screws are easy. That plug is worthless. There doesn’t appear to be an obvious way to unplug it. Some other videos show just pulling it off after removing the battery but then the surface mount plug breaks no matter how gentle. Please update to provide details on how to properly unplug the battery cable.
pcnate - crwdns2934203:0crwdne2934203:0
If anyone is still wondering about this: you just have to push back the metal clip on the mount. Then you can just lift off the connector.
Proprefenetre - crwdns2934203:0crwdne2934203:0
To anyone still having problems with the battery connector…there is a silver metal retaining clip that needs to be slid away (move towards the Chromebook’s screen) to “unlock” the battery connector. Then you can use a spudger or similar tool to go under all the wires of the connector just behind the white plastic and gently pry upwards to release it.
Reconnecting is simply a matter or pressing the white plastic connector back down where it came from, then using a tool to slide the metal retaining clip back down into place over the white plastic connector. I have run into this clip here and there and it’s frustrating until you figure it out.
Ryan Jaynes - crwdns2934203:0crwdne2934203:0
I got chromebook second hand with screws missing what size are ones at bottom touchpad end i tried 6mm but they push frame out
must be smaller if anyone can help
garry
garry gibbons - crwdns2934203:0crwdne2934203:0
LOL, when trying to replace mine, I tore that battery connector off the motherboard, it took some connections with it. Is it still repairable? Or do I need to give up on it?
Randy McGrew - crwdns2934203:0crwdne2934203:0
bonjour,
la batterie du chromebook est changée, elle est chargée mais pour démarrer l'ordinateur, je dois brancher le chargeur sur secteur puis l'éteindre pour utiliser la fonction batterie de l'ordinateur, il y a t-il une manipulation a faire pour indiquer que la batterie est neuve ?
je vous remercie !
Angéle - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 22,827
