Asus Chromebook C202SA-YS02 Daughterboard Replacement
  1. Asus Chromebook C202SA-YS02 Daughterboard Replacement, Palm Rest: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device over so the bottom is facing up.
    • Remove the ten Phillips #1 8.0 mm screws.
  2. Asus Chromebook C202SA-YS02 Daughterboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook C202SA-YS02 Daughterboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully use the plastic opening tool to pry the palm rest apart from the bottom cover. Start from one spot and systematically work your way around until the whole palm rest is detached.
  3. Asus Chromebook C202SA-YS02 Daughterboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two cables that run from the keyboard to the motherboard and from the touch pad to the motherboard.
    • You may have to use a spudger to lift open the respective latches.
  4. Asus Chromebook C202SA-YS02 Daughterboard Replacement, Daughterboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove both Phillips #1 4.5 mm screws from the daughterboard.
  5. Asus Chromebook C202SA-YS02 Daughterboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the thin band from the daughterboard. You may have to use a thin blade or spudger to lift the silver clip to release the band.
Beau Hansen
crwdns2935283:009/28/17crwdne2935283:0
845 crwdns2915208:0crwdne2915208:0
Idaho State University, Team S4-G4, Watkins Fall 2017 crwdns2935289:0Idaho State University, Team S4-G4, Watkins Fall 2017crwdne2935289:0
ISU-WATKINS-F17S4G4
crwdns2935297:020crwdne2935297:0
If I connected a wrong power supply to my notebook, (Input 120V 60Hz 12W, Output DC 9V, 500mA) with reversed polarity by accident, what if anything could have been burned/ruined? Thank you.
Navreet - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 834
