Having a hard time getting sound from your Chromebook? Made sure that your Chromebook wasn't muted? Then you may need to replace the speakers.
Remove Phillips #1 screws from the bottom of the Chromebook using a Phillips #1 screwdriver.
Ten 8 mm screws
Two of the screws are hidden by rubber caps along the rubber rest of the device. Use tweezers to get them out.
crwdns2935267:0crwdne2935267:0iFixit Opening Tool$1.99
Place the plastic opening tool into the edges between the front of the Chromebook and the back of it with the upper scoop of the opening tool facing upward.
Push down on the plastic opening tool to unhinge the top portion of the Chromebook from its lower portion. Opening the Chromebook all the way where the display touches the ground helps in opening up the top edge.
Use your hand to gently lift the top portion of the Chromebook from the bottom portion of it to avoid damaging the ribbon cables.
Gently disconnect the ribbon cable connecting the trackpad to the motherboard.
Gently disconnect the ribbon cable connecting the keyboard to the motherboard.
Use a spudger or a clean fingernail to flip up the locking flap on each end of the cable—this is the unlocked position.
Gently remove the ribbon cable connecting the I/O board to the motherboard.
Remove two 4 mm Phillips #1 screws from the metal grate connected to the battery.
Remove metal grate from battery.
Remove six 4 mm Phillips #1 screws from the battery.
Use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket and disconnect the battery from the motherboard.
If that doesn't work, grip all the cables at once as close to the connector as possible and pull the connector slowly and steadily out of its socket.
Lift the battery from the bottom edge to to remove it from the Chromebook.
Remove the black and white wires from the wireless card.
Unscrew the single 4 mm Phillips #1 screw pinning the wireless card in place.
Gently pull the wireless card away from the motherboard.
Unscrew one 3 mm Phillips #1 screw.
Unscrew one 2.5 mm Phillips #1 screw.
Unscrew four 4 mm Phillips #1 screws.
Disconnect the wires that connect the motherboard to the speakers.
Disconnect the motherboard from the display.
Lift the motherboard up and out of the chassis.
Lift the speakers away from the bottom portion of the Chromebook.
