Are your keys not clicking? Did you spill any liquids on your keyboard recently? This guide will help you resolve these situations.
Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
Use a plastic opening tool to pry the keyboard off the edges of the computer.
Flip up the white bar that connects the thin white strip using a plastic opening tool.
Grab the thin white strip and pull straight back to remove the strip from the connector.
Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
Grab the wide black strip and pull straight back to remove the strip from the connector.
Remove the keyboard by lifting it straight up.
