Asus Chromebook C201PA-DS02-LG Daughterboard Replacement
  1. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Keyboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
  6. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Metal Plate: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Metal Plate: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Metal Plate: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
    • Wiggle the plate back and forth to loosen the adhesive under the plate.
    • The adhesive will not be the same after removal and more adhesive may be necessary upon reassembly.
    • Rotate the screwdriver in a counterclockwise direction to remove the screws.
    • Do not rest your arm or hand in the adhesive.
  7. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Daughterboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Daughterboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to unscrew the two 4mm screws.
    • Flip up the white tab to remove the white ribbon cable.
  8. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to flip up the connector connecting the slim blue tipped strip to the daughterboard.
    • Lift the slim blue tipped strip from the daughterboard.
  9. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the plastic opening tools underneath the daughterboard.
    • Gently lift the daughterboard from the base of the device.
Brittany M Won
crwdns2935283:004/18/18crwdne2935283:0
577 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S17-G4, Livingston Spring 2018 crwdns2935289:0Cal Poly, Team S17-G4, Livingston Spring 2018crwdne2935289:0
CPSU-LIVINGSTON-S18S17G4
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 226
