Asus Chromebook C201 Trackpad Replacement
  1. Asus Chromebook C201 Trackpad Replacement, Trackpad: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First, flip over the chromebook.
  2. Asus Chromebook C201 Trackpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Then, pull off the plastic sliders on either side of the bottom of the computer using the spludger.
  3. Asus Chromebook C201 Trackpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew all of the screws in the back of the computer. Use a Phillips 1 screwdriver to remove the 8 1/2cm screws.
  4. Asus Chromebook C201 Trackpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the computer onto its side. Then, use a plastic opening tool to open the gap between the keyboard and the rest of the computer by slipping it between the two panels making up the body of the computer.
  5. Asus Chromebook C201 Trackpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the plastic opening tool around the length of the keyboard to free it from the laptop. Once the keyboard is free of the computer, lift the keyboard up gently until you can see and reach the two wires attaching it to the computer.
  6. Asus Chromebook C201 Trackpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the retaining flaps on the keyboard and trackpad ZIF connectors.
    • Gently pull the trackpad and keyboard ribbon cables out of their sockets on the motherboard.
  7. Asus Chromebook C201 Trackpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the keyboard off of the computer and flip it over.
  8. Asus Chromebook C201 Trackpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 2/10 cm screws holding the trackpad onto the keyboard using a Phillips head #000 screwdriver.
  9. Asus Chromebook C201 Trackpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry up the trackpad with a plastic opening tool. gently tilt the trackpad out of its slot and pull the trackpad out of the keyboard at an angle away from the slot.
  10. Asus Chromebook C201 Trackpad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place new trackpad into slot at an angle. Gently push new trackpad into the slot and press down on it very gently to make sure that it is completely in the slot.
  11. Asus Chromebook C201 Trackpad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the silver tabs onto board where they fall.
  12. Asus Chromebook C201 Trackpad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Screw in 2/10 cm screws to hold the trackpad onto the keyboard using a Phillips head #000 screwdriver.
  13. Asus Chromebook C201 Trackpad Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook C201 Trackpad Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Plug wires on keyboard back into their ports.
    • It may take a few tries to plug the wires back into the ports, because they use a tricky flap that snaps over the wire once you put it in place. Pull up the flap, place the wire fully onto the port, and snap the flap onto the wire.
  14. Asus Chromebook C201 Trackpad Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Snap keyboard back into place.
  15. Asus Chromebook C201 Trackpad Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Screw all 1/2 cm screws back into place using the Phillips head #1, and push the plastic sliders back into their slots.
Your replacement is now complete and your trackpad is as good as new... because it is new!
Samuel Farone
crwdns2935283:006/01/16crwdne2935283:0
141 crwdns2915208:0crwdne2915208:0
Central Coast New Tech High, Team 5-3, Rushing Spring 2016 crwdns2935289:0Central Coast New Tech High, Team 5-3, Rushing Spring 2016crwdne2935289:0
CCNTH-RUSHING-S16S5G3
where can i get the replacement track pad
broskie gang - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,033
