Asus Chromebook C101P Heat Sink Replacement
  1. Asus Chromebook C101P Heat Sink Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
  2. Asus Chromebook C101P Heat Sink Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
  3. Asus Chromebook C101P Heat Sink Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four black screws where the rubber grips were.
  4. Asus Chromebook C101P Heat Sink Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook C101P Heat Sink Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
  5. Asus Chromebook C101P Heat Sink Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebook C101P Heat Sink Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebook C101P Heat Sink Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
  6. Asus Chromebook C101P Heat Sink Replacement, Heat Sink: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook C101P Heat Sink Replacement, Heat Sink: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the the screen cables from the motherboard using a pair of tweezers.
    • Peel off the tape or seal to easily remove the screen cables.
  7. Asus Chromebook C101P Heat Sink Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip up the black lever on the base of the small white ribbon cable. Remove the cable and set it aside.
  8. Asus Chromebook C101P Heat Sink Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the nine Phillips #0 screws.
    • The 3 circles on the hand indicate that there are 3 more screws not visible in the photo.
    • Remove the battery cable if possible. Otherwise, gently flip the motherboard upside down to reveal the heat sink.
    • The motherboard may be hot. Be sure that you have left the Chromebook turned off for a few minutes.
  9. Asus Chromebook C101P Heat Sink Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Chromebook C101P Heat Sink Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four Phillips #0 screws from the heat sink.
    • Detach the heat sink from the motherboard.
    • Detaching may provide a bit of resistance because of thermal paste.
    • When you are ready to apply the new heat sink, be sure to apply a small dab of thermal paste onto the CPU.
Dan Sysopha
crwdns2935283:010/25/19crwdne2935283:0
369 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 crwdns2935289:0UMass Dartmouth, Team S1-G2, O'Connell Fall 2019crwdne2935289:0
UMASSD-O'CONNELL-F19S1G2
crwdns2942667:0crwdne2942667:0 1,105
