crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Asus Chromebit CS10crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The top image is the Chromebit with dust cap on its box next to a standard Sharpie for scale.
    • The circled screw in the second image is the write-protect screw, if you remove this and reassemble the Chromebit, if you boot in Developer Mode you are able to unlock the software write-protect and modify/replace the system firmware.
    • Using an iFixit spudger in the USB port stand it up to increase the gap to the sides of the USB port where you can insert a second spudger or a guitar pick and run it down each of the sides of the Chromebit to pop the case loose.
dragon788
crwdns2935283:008/20/16crwdne2935283:0
708 crwdns2915208:0crwdne2915208:0
ComputerPhreaks crwdns2935289:0ComputerPhreakscrwdne2935289:0
Business
How did you get this open? I’ve been using the spudger with out any luck. Is the case glued on by any chance? Thanks
Jimbo - crwdns2934203:0crwdne2934203:0
If you turn the end of the spudger sideways to get it started you should be able to undo the clips around the edges with a guitar pick. There is some resistance from the thermal pad.
dragon788 -
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 2,473
