Asus CM1745 Case Fan Replacement
  1. Asus CM1745 Case Fan Replacement, Case Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus CM1745 Case Fan Replacement, Case Fan: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the side panel by unscrewing the two screws fastening the panel on the rear.
    • Once unscrewed, slide the panel towards the rear until it releases then lift away.
  2. Asus CM1745 Case Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus CM1745 Case Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus CM1745 Case Fan Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3-pin fan connector from the 4-pin fan header on the motherboard by lightly pulling on the white plastic connector.
  3. Asus CM1745 Case Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus CM1745 Case Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus CM1745 Case Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four screws on the rear of the case. Keep the fan still by holding onto it with a spare hand.
    • Once the screws are removed, carefully lift the fan and its cable out, remembering its orientation.
  4. Asus CM1745 Case Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus CM1745 Case Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus CM1745 Case Fan Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take your replacement case fan and orient it in the same way as the previous fan.
    • Using the screws you just removed, secure the fan in place and reconnect to the fan header.
Once finished, plug in the computer and turn it on to test if the new fan works and is installed correctly. If everything works as it should, replace the side panel and resecure the screws in the rear.
TC Fowlar
crwdns2935283:010/30/19crwdne2935283:0
815 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S4-G2, Kim Fall 2019 crwdns2935289:0University of Memphis, Team S4-G2, Kim Fall 2019crwdne2935289:0
UM-KIM-F19S4G2
crwdns2942667:0crwdne2942667:0 1,718
