Asus A53U-ES21 Keyboard Replacement
    1. Asus A53U-ES21 Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A53U-ES21 Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Make sure the laptop is off.
      • Flip the laptop upside down so that the battery is facing you.
    2. Asus A53U-ES21 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A53U-ES21 Keyboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Move the two sliders towards the outer edge of the laptop.
      • Pull the battery out with your left hand while holding the right slider.
    1. Asus A53U-ES21 Keyboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Keyboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Keyboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the RAM cover from the bottom of the keyboard.
      • Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
      • Work the pry tool along the edge to finish removal.
      • Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
    2. Asus A53U-ES21 Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Keyboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Keyboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Orient the computer so the keyboard is facing toward you with the screen at the top.
      • Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
      • Use the pry tool to depress the buttons. The keyboard should pop out.
    3. Asus A53U-ES21 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Keyboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Keyboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Fold the keyboard out towards you. It should still be connected by a ribbon to the rest of the computer.
      • Gently use the opening tool to lift the black piece holding the ribbon down and remove the ribbon.
      • The black piece should cover the white line on the ribbon when it is replaced.
Mabel Trager
crwdns2935283:010/23/18crwdne2935283:0
180 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G3, Simcock Fall 2018 crwdns2935289:0UMass Dartmouth, Team S1-G3, Simcock Fall 2018crwdne2935289:0
UMASSD-SIMCOCK-F18S1G3
crwdns2935297:028crwdne2935297:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 941
