Asus A53U-ES21 Fan Replacement
  1. Asus A53U-ES21 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A53U-ES21 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
  2. Asus A53U-ES21 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A53U-ES21 Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
  3. Asus A53U-ES21 Fan Replacement, Optical Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Fan Replacement, Optical Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Fan Replacement, Optical Drive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 5mm screw using a Phillips #1 screwdriver.
    • Use the iFixit opening tools to remove the RAM panel.
  4. Asus A53U-ES21 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Fan Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 7mm screw using a Phillips #1 screwdriver.
    • Pull the optical drive out from the side of the laptop.
  5. Asus A53U-ES21 Fan Replacement, Keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Fan Replacement, Keyboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Fan Replacement, Keyboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the RAM cover from the bottom of the keyboard.
    • Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
    • Work the pry tool along the edge to finish removal.
    • Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
  6. Asus A53U-ES21 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the computer so the keyboard is facing toward you with the screen at the top.
    • Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
    • Use the pry tool to depress the buttons. The keyboard should pop out.
  7. Asus A53U-ES21 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fold the keyboard out towards you. It should still be connected by a ribbon to the rest of the computer.
    • Gently use the opening tool to lift the black piece holding the ribbon down and remove the ribbon.
    • The black piece should cover the white line on the ribbon when it is replaced.
  8. Asus A53U-ES21 Fan Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the laptop and place it upside down.
    • Remove the twelve 7mm screws using a Phillips #1 screwdriver.
  9. Asus A53U-ES21 Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 2mm screws using a Phillips #1 screwdriver.
  10. Asus A53U-ES21 Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A53U-ES21 Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the connectors away from the wireless card using the plastic opening tools.
    • Pull the white connector from its socket in the RAM panel.
  11. Asus A53U-ES21 Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over again, open it, and unscrew the three 7mm screws using a Phillips #1 screwdriver.
  12. Asus A53U-ES21 Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Fan Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull the tan flap off of the cable using the plastic opening tool.
    • Push the tan piece towards the cable and release it using the plastic opening tool.
    • Pull the black flap off of its connector.
  13. Asus A53U-ES21 Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A53U-ES21 Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the front plate of the laptop from the back using the plastic opening tool.
  14. Asus A53U-ES21 Fan Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Fan Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus A53U-ES21 Fan Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single 7mm screw from the motherboard using a Phillips #1 screwdriver.
    • Pull to two shown cables from their sockets using the plastic opening tools.
    • Gently remove the motherboard from the laptop.
  15. Asus A53U-ES21 Fan Replacement, Heat Sink: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the heat sink, unscrew the four 7mm screws using a Phillips #1 screwdriver.
    • Remove the heatsink from the device.
  16. Asus A53U-ES21 Fan Replacement, Fan: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A53U-ES21 Fan Replacement, Fan: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the fan, unscrew the three 5mm screws using a Phillips #1 screwdriver and pull the shown cable from its socket.
Justin Ogihara
crwdns2935283:009/18/17crwdne2935283:0
29.559 crwdns2915208:0crwdne2915208:0
crwdns2935297:052crwdne2935297:0
crwdns2942667:0crwdne2942667:0 607
