Asus A52F Cooling System Replacement
  1. Asus A52F Cooling System Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A52F Cooling System Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Asus A52F Cooling System Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A52F Cooling System Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Asus A52F Cooling System Replacement, Lower Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus A52F Cooling System Replacement, Lower Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus A52F Cooling System Replacement, Lower Case: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Asus A52F Cooling System Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A52F Cooling System Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the back panel away and remove the panel.
  5. Asus A52F Cooling System Replacement, Cooling System: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A52F Cooling System Replacement, Cooling System: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Removal of cooling system will void your warranty. Proceed with caution.
  6. Asus A52F Cooling System Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A52F Cooling System Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove all six screws from the cooling system.
    • Unplug the fan power connector.
  7. Asus A52F Cooling System Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A52F Cooling System Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully grab the copper pipe and start to lift upward.
    • Lift to the angle shown and then start to slide it out.
  8. Asus A52F Cooling System Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clean the designated area with isopropyl alcohol on a microfiber cloth
    • Replace with new thermal paste if needed
Bradley Varnum
crwdns2935283:003/09/17crwdne2935283:0
297 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S5-G1, Botvin Spring 2017 crwdns2935289:0UMass Dartmouth, Team S5-G1, Botvin Spring 2017crwdne2935289:0
UMASSD-BOTVIN-S17S5G1
crwdns2942667:0crwdne2942667:0 1,044
