Asus A4110 Disassembly
  1. Asus A4110 Disassembly, Open case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A4110 Disassembly, Open case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove screws at the circles
    • Remove gum strap and screw 5 screws out
    • Use a big screwdriver or some plastic to softly open the entire case around, starting at one down corner where your removed the screws before. The plastic clips will click a little. Don't be to hard.
    • Then you can lay the back next to the front, see second picture.
  2. Asus A4110 Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A4110 Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove VESA mount by 4 screws
    • Remove mainboard blend by 9 screws afterwards.
  3. Asus A4110 Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A4110 Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You can now replace harddrive or RAM easily. Remove harddrive to continue mainboard disassembly.
    • Remove WiFi module to continue disassembly. Watch for correct cable connection (they are crossed)
  4. Asus A4110 Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus A4110 Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus A4110 Disassembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove display cables by pulling the white plastic clip up from the cable side
    • Pull up the left clip same as the right one from first picture from cable side.
    • Then the touch connector (middle) must be opened from board side up, be patient and watch out for this, else your connector might be broken!
  5. Asus A4110 Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is how the connectors should now look like, see the marked position of the plastic strips.
  6. Asus A4110 Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove further connectors for USB, power, sound and keys.
  7. Asus A4110 Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus A4110 Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now remove 9 screws and the cooling screw to remove the mainboard.
Max
crwdns2935283:006/03/21crwdne2935283:0
175 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 66
crwdns2942667:0crwdne2942667:0 3,980
