Remove screws at the circles
Remove gum strap and screw 5 screws out
Use a big screwdriver or some plastic to softly open the entire case around, starting at one down corner where your removed the screws before. The plastic clips will click a little. Don't be to hard.
Then you can lay the back next to the front, see second picture.
Remove VESA mount by 4 screws
Remove mainboard blend by 9 screws afterwards.
You can now replace harddrive or RAM easily. Remove harddrive to continue mainboard disassembly.
Remove WiFi module to continue disassembly. Watch for correct cable connection (they are crossed)
Remove display cables by pulling the white plastic clip up from the cable side
Pull up the left clip same as the right one from first picture from cable side.
Remove further connectors for USB, power, sound and keys.
Now remove 9 screws and the cooling screw to remove the mainboard.
grazie della spiegazione
