Asus 1015E-DS03 Hard Drive Replacement
  1. Asus 1015E-DS03 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the laptop using both hands with the battery facing upwards.
    Halten Sie den Laptop mit beiden Händen so, dass der Akku nach oben zeigt.
    markus fri - crwdns2934203:0crwdne2934203:0
  2. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the two tabs located below the battery in towards each other using your thumbs.
    Drücken Sie die beiden Laschen, die sich unterhalb der Batterie befinden, mit den Daumen aufeinander zu.
  3. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the battery upwards and out of the laptop as shown.
    Schieben Sie den Akku wie abgebildet nach oben und aus dem Laptop heraus.
  4. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
    Schieben Sie den Akku weiter nach oben, bis er wie abgebildet vollständig vom Laptop getrennt ist.
  5. Asus 1015E-DS03 Hard Drive Replacement, Keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
    • Be very careful not to lose the screws, these four screws are very small.
  6. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After all four screws are removed, flip the laptop over with the keyboard facing up.
    • Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
    • It is normal to hear cracking noises when prying off the keyboard.
    • After keyboard is detached from laptop, there is a ribbon cable still attached to the motherboard. See next step before completely removing keyboard.
    I started with the 2 sides of the keyboard. Then the rear edge has 5 tabs in the battery compartment, which seem to be critical to getting the keyboard off. The front edge of the keyboard does not need to be pried off. It has metal tabs that slide into slots.
    Matt Knutson - crwdns2934203:0crwdne2934203:0
  7. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
    • Be careful not to tear or rip the ribbon cable.
  8. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger push the white clips upwards that are holding the cable.
  9. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the strip out of the square slot.
    How do you remove the black metal cover on top of the motherboard? See your second photo.
    John Suomi - crwdns2934203:0crwdne2934203:0
    If anyone still needs this answered, in the 1015PX I've opened up again recently, there are another 6 screws (I think) attaching the black cover to the motherboard/bottom case, then you need to prise the wrist/touchpad section up with a spudger because it's all one moulding.
    Neil Hughes - crwdns2934203:0crwdne2934203:0
  10. Asus 1015E-DS03 Hard Drive Replacement, Hard Drive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus 1015E-DS03 Hard Drive Replacement, Hard Drive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the keyboard is removed, the base plate will be exposed
    • Please note that 1 screw will be covered by the warranty sticker (not shown). To complete this step it is necessary to break the warranty sticker which voids the laptop warranty.
    • Remove the 3mm screws (11) using a #0 Phillips head screwdriver
  11. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to 'pop' open the track-pad base, starting from the corner shown
    • Once the corner is popped it may be easier to use your fingers to pop off the entire track-pad base
    • You will hear popping. Although this is normal, use caution pulling the track-pad base from the rest of the laptop
  12. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You can now lift both sections of the base, exposing the hard drive.
  13. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Release the two ZIF connectors that are labeled "IO"
    • The white bar flips away from the ribbon cable, then the ribbon cable can be gently pulled and removed from the connector
  14. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the hard drive from the laptop by pulling it towards the right.
TJ Hanley
crwdns2935283:003/21/16crwdne2935283:0
221 crwdns2915208:0crwdne2915208:0
Clemson, Team 7-4, Benson Spring 2016 crwdns2935289:0Clemson, Team 7-4, Benson Spring 2016crwdne2935289:0
CLEM-BENSON-S16S7G4
I pulled out the hard drive from a working 1015PE. I have all the parts and most of the screws.
I am not going to put it back together.
Can anyone use the what is left?
B&R Computer Services.
Contact info at noappleis2old4us.com
January 26, 2023
Ron Re - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 2,400
