Replacing a hard drive may be necessary if you are experiencing frequent crashes, data loss or file corruption. You also can upgrade the hard drive to store more data. Either way, just follow this simple guide!
Hold the laptop using both hands with the battery facing upwards.
Push the two tabs located below the battery in towards each other using your thumbs.
Push the battery upwards and out of the laptop as shown.
Continue to push the battery upwards until it is completely separated from the laptop as shown.
Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
After all four screws are removed, flip the laptop over with the keyboard facing up.
Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
Using the spudger push the white clips upwards that are holding the cable.
Gently pull the strip out of the square slot.
Once the keyboard is removed, the base plate will be exposed
Remove the 3mm screws (11) using a #0 Phillips head screwdriver
Use the spudger to 'pop' open the track-pad base, starting from the corner shown
Once the corner is popped it may be easier to use your fingers to pop off the entire track-pad base
You can now lift both sections of the base, exposing the hard drive.
Release the two ZIF connectors that are labeled "IO"
The white bar flips away from the ribbon cable, then the ribbon cable can be gently pulled and removed from the connector
Gently remove the hard drive from the laptop by pulling it towards the right.
I pulled out the hard drive from a working 1015PE. I have all the parts and most of the screws.
I am not going to put it back together.
Can anyone use the what is left?
B&R Computer Services.
Contact info at noappleis2old4us.com
January 26, 2023
