Asus 1015E-DS03 Hard Drive Replacement
    1. Asus 1015E-DS03 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Hold the laptop using both hands with the battery facing upwards.
    2. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Push the two tabs located below the battery in towards each other using your thumbs.
    3. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Push the battery upwards and out of the laptop as shown.
    4. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Continue to push the battery upwards until it is completely separated from the laptop as shown.
    1. Asus 1015E-DS03 Hard Drive Replacement, Keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
      • Be very careful not to lose the screws, these four screws are very small.
    2. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • After all four screws are removed, flip the laptop over with the keyboard facing up.
      • Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
      • It is normal to hear cracking noises when prying off the keyboard.
      • After keyboard is detached from laptop, there is a ribbon cable still attached to the motherboard. See next step before completely removing keyboard.
    3. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
      • Be careful not to tear or rip the ribbon cable.
    4. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the spudger push the white clips upwards that are holding the cable.
    5. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently pull the strip out of the square slot.
    1. Asus 1015E-DS03 Hard Drive Replacement, Hard Drive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus 1015E-DS03 Hard Drive Replacement, Hard Drive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the keyboard is removed, the base plate will be exposed
      • Please note that 1 screw will be covered by the warranty sticker (not shown). To complete this step it is necessary to break the warranty sticker which voids the laptop warranty.
      • Remove the 3mm screws (11) using a #0 Phillips head screwdriver
    2. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the spudger to 'pop' open the track-pad base, starting from the corner shown
      • Once the corner is popped it may be easier to use your fingers to pop off the entire track-pad base
      • You will hear popping. Although this is normal, use caution pulling the track-pad base from the rest of the laptop
    3. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • You can now lift both sections of the base, exposing the hard drive.
    4. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Release the two ZIF connectors that are labeled "IO"
      • The white bar flips away from the ribbon cable, then the ribbon cable can be gently pulled and removed from the connector
    5. Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus 1015E-DS03 Hard Drive Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently remove the hard drive from the laptop by pulling it towards the right.
TJ Hanley
crwdns2935283:003/21/16crwdne2935283:0
221 crwdns2915208:0crwdne2915208:0
Clemson, Team 7-4, Benson Spring 2016 crwdns2935289:0Clemson, Team 7-4, Benson Spring 2016crwdne2935289:0
CLEM-BENSON-S16S7G4
crwdns2935297:084crwdne2935297:0
I pulled out the hard drive from a working 1015PE. I have all the parts and most of the screws.
I am not going to put it back together.
Can anyone use the what is left?
B&R Computer Services.
Contact info at noappleis2old4us.com
January 26, 2023
Ron Re - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 68
crwdns2942667:0crwdne2942667:0 2,973
