Here are some instructions on how to change the old Battery of Astro Pyle PTBL7C and install a new one.
Use the spudger to open the device from the front edge of the screen. Gently slide it in and push it up to open.
The battery will appear as pictured. Separate the back case from the device. Avoid damaging the wire that connects the speakers between the two halves of the case.
The battery is attached in two different ways; one wire is attached to the screen to support the screen's background led lights. Carefully desolder the wire without damaging the part connecting the battery to the screen.
Desolder the wires pictured. These feed energy from the battery into the motherboard.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Use a plastic card to gently break the adhesive holding the battery to the metal screen plate. Remove the battery.
Install the new battery and solder all the connections back in place.
