Astro Mixamp USB Port Replacement
  1. Astro Mixamp USB Port Replacement, Panel Dial: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro Mixamp USB Port Replacement, Panel Dial: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the dial tightly and pull straight off the device.
    • Repeat for the second dial
  2. Astro Mixamp USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro Mixamp USB Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, remove the spacer nuts and washers from each dial post.
  3. Astro Mixamp USB Port Replacement, Outer Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro Mixamp USB Port Replacement, Outer Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before opening your device, ensure the device is not on or connected to the charging cable.
    • Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
    • Pull the rubber foot free of the plastic casing.
  4. Astro Mixamp USB Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a screwdriver to remove the screw from the rear casing.
  5. Astro Mixamp USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the rear casing from the device.
  6. Astro Mixamp USB Port Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Astro Mixamp USB Port Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Astro Mixamp USB Port Replacement, Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four screws that hold the motherboard in place.
    • Only touch the edges of the motherboard. Touching the surface can damage the motherboard.
  7. Astro Mixamp USB Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the motherboard from the front cover.
  8. Astro Mixamp USB Port Replacement, USB Port: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Astro Mixamp USB Port Replacement, USB Port: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Astro Mixamp USB Port Replacement, USB Port: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the tip of a hot soldering iron to the USB connection to melt the solder.
    • Use a nylon spudger to lift the USB from the solder.
    • Repeat for each of the four USB connections.
    • For more help on soldering, refer to this guide: How To Solder and Desolder Connections
Hope Burns
crwdns2935283:010/29/16crwdne2935283:0
741 crwdns2915208:0crwdne2915208:0
What port is used as a replacement?
jonescoleman1738 - crwdns2934203:0crwdne2934203:0
Did you ever identify an appropriate replacement port?
Lepec -
something was broken out of the port of the USB connection
MoreZemtor - crwdns2934203:0crwdne2934203:0
Will this method work with the 2015 tr mixamp?
jeffreyalvarez9 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 8,184
