Astro Mixamp USB Port Replacement
  1. Astro Mixamp USB Port Replacement, Panel Dial: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro Mixamp USB Port Replacement, Panel Dial: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the dial tightly and pull straight off the device.
    • Repeat for the second dial
  2. Astro Mixamp USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro Mixamp USB Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, remove the spacer nuts and washers from each dial post.
  3. Astro Mixamp USB Port Replacement, Outer Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro Mixamp USB Port Replacement, Outer Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before opening your device, ensure the device is not on or connected to the charging cable.
    • Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
    • Pull the rubber foot free of the plastic casing.
  4. Astro Mixamp USB Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a screwdriver to remove the screw from the rear casing.
  5. Astro Mixamp USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the rear casing from the device.
    The Astro Mixamp Pro is largely the same process as this, except there are some plastic tabs on the rear casing holding it onto the front plate. Carefully work along the seams on the long sides and the corners with something flat and stiff, gently levering the rear housing out and away from the front plate to disengage the plastic tabs. With enough patience and care, they'll pop out of their spots and the casing will be free.
    foshwosh - crwdns2934203:0crwdne2934203:0
  6. Astro Mixamp USB Port Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Astro Mixamp USB Port Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Astro Mixamp USB Port Replacement, Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four screws that hold the motherboard in place.
    • Only touch the edges of the motherboard. Touching the surface can damage the motherboard.
  7. Astro Mixamp USB Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the motherboard from the front cover.
  8. Astro Mixamp USB Port Replacement, USB Port: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Astro Mixamp USB Port Replacement, USB Port: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Astro Mixamp USB Port Replacement, USB Port: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the tip of a hot soldering iron to the USB connection to melt the solder.
    • Use a nylon spudger to lift the USB from the solder.
    • Repeat for each of the four USB connections.
    • For more help on soldering, refer to this guide: How To Solder and Desolder Connections
Hope Burns
crwdns2935283:010/29/16crwdne2935283:0
741 crwdns2915208:0crwdne2915208:0
What port is used as a replacement?
jonescoleman1738 - crwdns2934203:0crwdne2934203:0
Did you ever identify an appropriate replacement port?
Lepec -
something was broken out of the port of the USB connection
MoreZemtor - crwdns2934203:0crwdne2934203:0
Will this method work with the 2015 tr mixamp?
jeffreyalvarez9 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 8,202
