crwdns2959928:0crwdne2959928:0 ↓Use when the USB port needs to be removed. (Soldering Required)
Spudger4.9
Grip the dial tightly and pull straight off the device.
Repeat for the second dial
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, remove the spacer nuts and washers from each dial post.
Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
Pull the rubber foot free of the plastic casing.
Use a screwdriver to remove the screw from the rear casing.
Gently lift the rear casing from the device.
Remove the four screws that hold the motherboard in place.
Gently pull the motherboard from the front cover.
Press the tip of a hot soldering iron to the USB connection to melt the solder.
Use a nylon spudger to lift the USB from the solder.
Repeat for each of the four USB connections.
What port is used as a replacement?
jonescoleman1738 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Did you ever identify an appropriate replacement port?
Lepec - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
something was broken out of the port of the USB connection
MoreZemtor - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Will this method work with the 2015 tr mixamp?
jeffreyalvarez9 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
