Astro Mixamp Control Button Replacement
  1. Astro Mixamp Control Button Replacement, Panel Dial: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro Mixamp Control Button Replacement, Panel Dial: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the dial tightly and pull straight off the device.
    • Repeat for the second dial
  2. Astro Mixamp Control Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro Mixamp Control Button Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, remove the spacer nuts and washers from each dial post.
  3. Astro Mixamp Control Button Replacement, Outer Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro Mixamp Control Button Replacement, Outer Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before opening your device, ensure the device is not on or connected to the charging cable.
    • Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
    • Pull the rubber foot free of the plastic casing.
  4. Astro Mixamp Control Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a screwdriver to remove the screw from the rear casing.
  5. Astro Mixamp Control Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the rear casing from the device.
  6. Astro Mixamp Control Button Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Astro Mixamp Control Button Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Astro Mixamp Control Button Replacement, Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four screws that hold the motherboard in place.
    • Only touch the edges of the motherboard. Touching the surface can damage the motherboard.
  7. Astro Mixamp Control Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the motherboard from the front cover.
  8. Astro Mixamp Control Button Replacement, Control Button: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro Mixamp Control Button Replacement, Control Button: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently insert a metal spudger under a control button housing.
    • Do not pry the button housing from the front panel, this can cause damage to the button.
    • Rotate the control button around the marked pin.
Hope Burns
crwdns2935283:010/29/16crwdne2935283:0
741 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 1,758
