Don’t abandon your Astro C40 TR controller if it has some drift problems! With a new joystick module, some screwdrivers, and minor effort, it’ll be as good as new.
Apart from being able to use a screwdriver, this guide requires no prerequisite on technical background.
You will need:
- An H.20 Hexagonal Screwdriver
- A 30mm TORX Screwdriver
- A joystick module for replacement
Unplug your controller from the video game console.
Turn the wireless mode off if it is activated on your controller.
Use an H.20 Hexagonal screwdriver to loosen the two screws on each joystick's side.
Remove the face cover of the joystick by flipping the controller on its side.
Use the 30mm TORX Screwdriver to remove the screws from the module.
Push on the top frame until it pops off of the module.
Connect the base frame replacement to the joystick module.
Insert the top frame on the module until it clicks back together.
Reassemble the joystick module and plug it back into the controller.
Make sure the replacement and base frame are tightly screwed together.
Align the module and controller as you put joystick back together.
Reassemble the controller by placing the face cover back on.
Tighten the screws on the face cover with the H.20 Hexagonal Screwdriver.
Recalibrate the controller so the new joystick can be detected by the console.
Connect the controller to the console and activate wire-connect mode by clicking the controller's top right corner.
Push the button on the back of the controller. Hold it until the controller vibrates. Release the button and repeat.
